Jetex Carb Choke Plunger
Postby Granty » Sat Mar 23, 2019 10:06 pm
Guys -- doing some trouble shooting on a difficult starter, standard 200 lump with 42mm clubman, jetting all good -- quick question when you turn the choke lever should the plunger move halfway or travel fully up the cylinder? My carb floods very easily on starting. Just playing around with things just now -- cheers G
Granty
Re: Jetex Carb Choke Plunger
Postby CHRIS in MARGATE » Sat Mar 23, 2019 10:57 pm
Keep the throttle shut.
Postby HxPaul » Mon Apr 01, 2019 2:03 pm
Granty wrote:Guys -- doing some trouble shooting on a difficult starter, standard 200 lump with 42mm clubman, jetting all good -- quick question when you turn the choke lever should the plunger move halfway or travel fully up the cylinder? My carb floods very easily on starting. Just playing around with things just now -- cheers G
Try starting it without choke,if it starts and revs ok,your main jet or pilot jet (the pilot jet takes its fuel from the main jet) may be to big.
Return to Carburettors
