Steering Wobble GP200
Postby NLEMECFC » Mon Apr 29, 2019 2:02 pm
Any thoughts welcome on what could be causing a steering wobble on my GP200 as it's currently got myself and my mechanic flummoxed. It's progressive if I let go of the handle bars (I know, don't let go of them then!) and have tried a few of the usual suspects and trying to avoid having to remove the forks. Tyre pressure correct; headstock is tight; taking the dampers off doesn't cure it. Thoughts?
NLEMECFC
Re: Steering Wobble GP200
Postby Adam_Winstone » Mon Apr 29, 2019 2:10 pm
Tighten the 2 halves of the front hub together by the inner nut on the spindle. This is a common cause.
Adam
PS - Then don't forget to do up the outer link nuts too as the hub may have closed up.
Postby hullygully » Mon Apr 29, 2019 4:51 pm
also check those wheel rims, I've had 2 mates with SH*TE cheapo Indibum ones, death traps!!!!!!!!! :( :evil:
Postby HxPaul » Mon Apr 29, 2019 5:25 pm
Check rear hub for tightness,if loose it could be - rear hub bearing,the bearing on the endplate,or a loose endplate.
Postby Bogie » Mon Apr 29, 2019 6:47 pm
As above endplate bearings .... just had a similar problem with mine , changed wheels , hubs , engine mounts etc and it turned out to be my layshaft needle bearings had disintigrated .
Bogie
Postby hullygully » Tue Apr 30, 2019 11:13 am
engine mounts affect the rear end (my TV twice :( )
Postby HxPaul » Tue Apr 30, 2019 3:00 pm
What effects the rear end,can be felt at the front.
Postby hullygully » Tue Apr 30, 2019 4:38 pm
my engine mounts goin could only be felt on a long straight rode or on bends @ the rear end :?
where-as with my 2-mates dodgy front wheel rims you struggled to hold on above 40mph on a short stretch!!!!!!! :o
Postby martyn dwane » Wed May 01, 2019 11:45 am
i had a rear hub nut thats wasnt full threaded once , tightened up with usual torque setting , by the time i had ridden 60 miles the front
end felt like it was rolling side to side .as the nut/ cone were getting slacker.
bought new rear nut , rolling sensation gone.
martyn dwane
Postby hullygully » Wed May 01, 2019 12:02 pm
any news from this thread starter NLEMECFC :lol:
Postby NLEMECFC » Thu May 02, 2019 4:16 pm
Thanks for all the suggestions guys, going over to my mechanic tomorrow hopefully and will run them past him - pretty shit at anything like this myself so will refer them to the expert and let you know what he says. To add to what I'd already said, as long as I don't let go of the bars then she's very ridable right up to and including top cruising speed, the wobble only really sets in if I let go though of course you can feel it beforehand. Cheers, Neil
NLEMECFC
Postby hullygully » Thu May 02, 2019 4:37 pm
defo not the wheel rims then as you want to jump off @ 40mph never mind top cruising speed!!!! :lol:
Postby Fast n Furious » Fri May 03, 2019 11:20 pm
TBH
If the suspension is original or the forks haven't been rebuilt in a long time then it could just be down to fair wear and tear. In which case, have them rebuilt by someone who knows what they're doing.
Users browsing this forum: Bing [Bot] and 24 guests
