phbh slide
phbh slide
Postby Simon_T » Tue Apr 30, 2019 10:30 pm
Hi All,
question is if I change the slide I have in my 30mm phbh from 40 to 45 would this have a dramatic affect all through out the range and dan
gerously weak...?
Simon_T
Re: phbh slide
Postby hullygully » Wed May 01, 2019 8:26 am
why are you changing it first?
do a plug chop thru the 4 rev ranges 8-)
Re: phbh slide
Postby Hat » Wed May 01, 2019 8:31 am
the slide only affects just coming off idle up to 1/4 throttle so to answer your question, no it won’t make it weak across the full range
Hat
Re: phbh slide
Postby Warkton Tornado No.1 » Wed May 01, 2019 5:36 pm
Simon_T wrote:Hi All,
gerously weak...?
It depends upon interpretation.
Although the slide affects the lower part of the range, from which point, in the upper range, the atomiser, needle, main jet & power jet (if fitted) take over in the upper range, any engine has to get through the lower range to get to the upper range & back down again.
If you get my drift, the lower range is, therefore, fairly critical.
Because a 40 slide is fairly common with all non-SH type derivatives of Dell’Orto’s utilised on Lambrettas, have you considered modifying what you have?
By removing material from the lower edge, a 40 slide can be converted to a 45, or even, say, a 42.5. Knowledgeable tuners, such as Taffspeed, used to carry out precisely that modification @ times.
Side by side comparisons enable measurement with a Vernier to calculate the amount of material to be removed.
(Do be aware that for the cost of a new slide, a brand new PWK with all likely jet kits can be purchased that some of us consider far superior…..)
Re: phbh slide
Postby Simon_T » Fri May 03, 2019 9:02 pm
hullygully wrote:why are you changing it first?
the reason why I was gonna change the slide from 40 to 45 was a friend has same setup with 30mm phbh Avanti ex box exhaust he had it dynode and I thought 40 was the norm and thought his would be lean, he doesn't do a lot of miles in paticular motorway miles so I copied his setup I thought maybe mine would go bang on the motorway and in particular when rolling off the throttle.
Simon_T
Re: phbh slide
Postby Storkfoot » Fri May 03, 2019 9:25 pm
On my GT 186, I took a small file to my 40 and made it 42/43. Was spot on. I’d tried a 45 beforehand but it was too lean.
Personally, I don’t think I have heard of anyone successfully running a 45. I still have the 45 if you want to borrow it.
Re: phbh slide
Postby Simon_T » Fri May 03, 2019 9:35 pm
Storkfoot wrote:On my GT 186, I took a small file to my 40 and made it 42/43. Was spot on. I’d tried a 45 beforehand but it was too lean.
cheers stork foot I have both options available but like I said a friend has the same setup and had it dynode and has a 45 in but it don't sound right to me I would rather err on the side of caution and go 40, to witch ill test it and do plug chops rather than depend on his setup although dynode by a reputable tuner.
Simon_T
Return to Carburettors
Users browsing this forum: No registered users and 8 guests
