model D front brake
model D front brake
Postby noel » Tue May 14, 2019 6:11 pm
Does anybody know if the inner surface of the drum can be skimmed on a model D? Mine is Very rusty and there wasn't a great deal of cast iron for the braking surface to begin with.
noel
Re: model D front brake
Postby jbcollier » Fri May 17, 2019 8:52 pm
If it is just rusty, then use 80 grit sandpaper and clean it up. If it is badly scored, replace it.
jbcollier
Postby noel » Wed May 22, 2019 6:53 pm
Thanks, its beyond just rusty so it has to go
noel
Postby jbcollier » Fri May 24, 2019 2:04 pm
Give it a go with sandpaper first. You never know.
jbcollier
Return to Pre 57
