Front break conversion & speedo drive set up - Issues
Postby Herbert » Sun Jun 09, 2019 2:33 pm
Hi all.
I am looking for some guidance and hope someone can help, please.
I'm trying to help a friend who has an external hydraulic break conversion on his GP. The make is 'SPAQ'.
The problem is, is that we cannot get the steel worm (driven) gear to mesh with the steel (drive) gear fitted to the hub once the inner speedo cable to located into the drive bush (steel drive retaining housing) and tightened down . When the wheel is spun, the inner cable turns freely when it located into the end of the worm gear and whilst in the hub WITHOUT the drive bush! This seems to suggest the drive bush (drive retaining housing) is at issue?!
Have others had similar issues? Am I overlook something? Any suggestions? Can you recommend a particular supplier who supplies a speedo kit to overcome the problem?
Essentially, its 'doing my head-in' and any guidance would be very much welcome.
Many thanks. H.
Herbert
Re: Front break conversion & speedo drive set up - Issues
Postby shane BBoys » Sun Jun 09, 2019 3:25 pm
Hi.
This will not help but I have a Spaq pepper pot hydraulic and 4 years on I still have no joy with my speedo however it gives the correct mileage covered. I reverted to using my phone using a speedo App although I have just purchased a Garmin 201 to use.
Cheers Shane.
shane BBoys
Postby lammydave » Mon Jun 10, 2019 5:26 am
i have similar issues with a spaq set up, never managed so far to get a speedo drive that will work.... the scootRs ones were fine....
lammydave
Postby Herbert » Mon Jun 10, 2019 7:10 pm
Thanks for your comments.
Hmmm, more experiments needed I think!
Herbert
Users browsing this forum: Google [Bot] and 14 guests
