Tank sealant options
Postby Knowledge » Mon Jun 10, 2019 12:37 pm
I have used Petseal in the past, and it has flaked off inside the tank. I know others have had the same problem.
Does anyone know of a better product?
Re: Tank sealant options
Postby ULC Soulagent » Mon Jun 10, 2019 12:46 pm
Kreem is decent stuff, 3 stages involved which is a bit of a Flaff but works a treat
ULC Soulagent
Postby Storkfoot » Mon Jun 10, 2019 4:50 pm
Search for Tankcare Products. They even do a Petseal Remover too which probably tells you all you need to know about that particular product.
I have only used Tankcare on 2 tanks that both needed welding. This is why I used it. In both cases, with correct preparation, the tanks sealant is still sound years later.
Postby col68 » Mon Jun 10, 2019 6:43 pm
Think I would treat myself to a new tank
col68
Postby Storkfoot » Mon Jun 10, 2019 9:30 pm
col68 wrote:Think I would treat myself to a new tank
Waste not, want not ;)
Postby Norrie Bodge » Mon Jun 10, 2019 9:37 pm
Knowledge wrote:I have used Petseal in the past, and it has flaked off inside the tank. I know others have had the same problem.
POR15 I used as recommended by Ben at AF
3 years on & Been ok so far
Norrie Bodge
Postby Chadley » Mon Jun 10, 2019 11:11 pm
Storkfoot wrote:Search for Tankcare Products. They even do a Petseal Remover too which probably tells you all you need to know about that particular product.
+1.
I used this stuff on my tank in 2012, it's still doing the job well.
Chadley
Postby Tractorman » Tue Jun 11, 2019 10:11 am
I'll go with POR15. I've used it on several tanks including tractor tanks without problems.
Postby Dazts1 » Tue Jun 11, 2019 10:06 pm
I’m using tankcare products in my longrange tank. It’s been in since sept last year all seems good. It did have petseal In Which failed.
Postby bluebob » Sat Jun 15, 2019 10:43 pm
POR15
bluebob
Postby Fast n Furious » Sun Jun 16, 2019 1:22 am
POR15 deffo
Postby lam1962brettagg » Mon Jun 17, 2019 8:47 pm
oxalic acid mix 1:3 with water. leave to soak 24 hours. longer if rust is really bad.
then flush with bicarb of soda as acid nutalizer and flush with water. then get it dry with a heat gun or hairdryer before flash rust.
oil in petrol will then stop any rusting.
should be like new then and stay clear for years.
:D
i did try petseal before i tried oxalic. petseal crap
lam1962brettagg
Users browsing this forum: Google [Bot] and 19 guests
