by shane BBoys » Sat Jun 15, 2019 8:37 pm
How do?
Do any of you have a photo you can share of a series 2 Eibar mudguard fitted to the forks prior to the forks being installed?
Cheers Shane
shane BBoys
by Watfordwhite » Sun Jun 16, 2019 8:09 am
Shane,
If your fitting them to an Italian S2 you have to remove the dust cover from the lower fork bearings.
If your using Spanish forks that already have the ring in place. You should have two more rings. Inner and outer.
Watfordwhite
by shane BBoys » Sun Jun 16, 2019 12:17 pm
Martin.
It’s going on Spanish forks, it is a fibreglass 1 from Chris, I’ve had the Dremel out and have got it push down as far as possible, I want to get it on prior to put on the finish.
Cheers Shane.
shane BBoys
