side panel buffers
side panel buffers
Postby gazzar15 » Wed Aug 07, 2019 3:51 pm
Wanting to fit my side panels but currently looking on the best way to fit the rubbers and clips....had a couple of go's and it is indeed a pig of a job !!
gazzar15
Re: side panel buffers
Postby dickie » Wed Aug 07, 2019 5:33 pm
On s1 or s2, some oil, grease, spit will lubricate it enough to slide on easily.
If you've got s3, and have bought "quality stainless clips", bun them and find some original ones. They're about 25% too small.
Postby burnside » Thu Aug 08, 2019 1:32 pm
S1 or S2 just stick them in a mug of boiling water for 5 mins, should go on easily enough without the need to extra lube.
S3, unless you are really being picky about looks underneath your panels, cable tie them on?
burnside
Postby HxPaul » Thu Aug 08, 2019 1:58 pm
s3 panel buffers,I just open them with a flat bladed screwdriver and push them on.
https://www.ebay.co.uk/itm/Lambretta-Si ... SwQJhUlJHI
s1 and s2 there easiest if you put them on back to front and turn them once there on.
Users browsing this forum: Peterp and 10 guests
