Chimpboy74 wrote:I dont really fancy that..... I'm not great with pain.
Chimpboy74 wrote:I did remove the cap and got a spark from the HT cable. I probably should try again as I'm not sure I was that far away. I guess there will be a spark but I'm guessing the distance is key to determining of it's good enough?
If it isn't should I be replacing the CDI as well as cable?
Chimpboy74 wrote:I can't help but feel that the fact that it nearly starts first kick after it's been left sitting for a few days should tell me something.
If I leave it for 3 or 4 days and then try and start it it almost starts but stops immediately. It doesn't get even close again until it has been left for a few days again. The plug is definitely wet. I kicked it over a few times with spark plug out and fuel and choke off and a little bit comes out but not loads.
Not sure if anyone has any thoughts on why it might almost start after sitting?
Re: Spark plug question
Unread postby MickYork » Thu Sep 05, 2019 9:03 pm
bite the bullet......put your finger in the suppressor cap and kick it over......you'll know if your getting voltage or not.
I'm being serious by the way.
Users browsing this forum: No registered users and 8 guests
