Rear hub keeps coming loose
Postby Barsey » Sat Oct 12, 2019 8:07 pm
Asking for a friend! Rear hub keeps coming loose, regardless of how tight nut is tightened. Using a lock washer with three lock pins! Nut has been replaced and is not worn. Engine/gearbox was rebuilt about two years ago and is only used a couple of times a week. Is this a gearbox strip-down job? Totally stumped!
Barsey
Re: Rear hub keeps coming loose
Postby ToBoldlyGo » Sat Oct 12, 2019 8:21 pm
Possibly the wrong cone for the hub.
ToBoldlyGo
Postby Norrie Bodge » Sat Oct 12, 2019 8:23 pm
+1 on hub cone
& Are the threads on layshaft ok?
Norrie Bodge
Postby MickYork » Sat Oct 12, 2019 8:42 pm
spacer behind hub ? maybe fit a thicker one ?
Postby Scooterdude » Sat Oct 12, 2019 10:38 pm
What’s this latest trend of “asking for a friend “ all about then?
Scooterdude
Postby HxPaul » Sun Oct 13, 2019 10:41 am
Check the thread on the layshaft.And the layshaft isn't breaking.
Postby bsso78 » Sun Oct 13, 2019 11:14 am
There were some layshafts around a couple of years ago that didn’t have the thread cut far enough to tighten the hub onto the cone properly. What make is yours?
bsso78
Postby missing lynx » Sun Oct 13, 2019 12:37 pm
Is it an aftermarket stainless nut if so the dome could be too shallow and have no nyloc in it so its tightening against the leyshaft and not the hub meaning no matter how tight it is it will never pull the hub onto the cone enough and will come undone once ridden
Postby CHRIS in MARGATE » Sun Oct 13, 2019 12:46 pm
When you tighten it, grab it and really try to rock it to check for play. Place an additional washer under the hub nut and retighten and see if this removes any perceptible movement. Now you have to ascertain if it's the threaded layshaft or the hub nut.
DO NOT RIDE IT WITH ADDITIONAL WASHERS.
Postby Warkton Tornado No.1 » Sun Oct 13, 2019 12:46 pm
Previous to this Post, I've mentioned the problem of hub nuts maintaining the correct torque on this Forum.
I can't recall anybody agreeing, but my belief is that certain remade cones are simply not hard enough, & consequently the spline of the lay shaft actually bites into the bore of the remade cones, which then means the whole assembly does not remain as tight as it should be.
Old OEM cones always have a fairly good finish to the bore, whereas the ones that I consider 'soft' will have a slightly splined bore after use.
Postby Barsey » Mon Oct 14, 2019 5:11 pm
Thanks everybody for your input. ‘Asking for a friend’ is me trying to get some info for a good friend who has this little issue. I’ll let you know what develops.
Barsey
Users browsing this forum: Bing [Bot] and 19 guests
