Rear hub stud thread
Postby puggie6653 » Tue Nov 26, 2019 10:26 pm
Hi All, can anyone tell me the dia and pitch of a rear hub stud hole on a Lammy , as I want to buy a tap / die Cheers TIA
puggie6653
Re: Rear hub stud thread
Postby Toddy » Wed Nov 27, 2019 7:03 am
Moved into here you should get a better respone
Cheers Toddy
Postby HxPaul » Wed Nov 27, 2019 10:08 am
Remember its a left hand thread.What I've done in the past when a threads gone is to put in an ordinary m8 bolt and use the nut off the original stud.
Postby Toddy » Wed Nov 27, 2019 10:24 am
Std metric coarse pitch for M10 should be 1.5mm. the hub studs are left hand M10 x 1.
You can get the tap from eBay, Chinese ones are cheap enough and adequate for the job of cleaning up threads. They take abou a week to arrive.
Postby puggie6653 » Wed Nov 27, 2019 1:35 pm
Cheers guys all received and understood
puggie6653
