Ts1 replacement piston Ron Moss Matika piston
Re: Ts1 replacement piston Ron Moss Matika piston
Postby Scooterdude » Sun Nov 24, 2019 12:18 pm
al pushpak wrote:I thought the Casa pistons had the same crown heights as the asso's 39mm but then again all this piston malarkey has definitely been a learning curve lol! :D
Its the dome height on the casa blackline Piston that is different, much flatter than the usual 7mm dome height of the Meteor, Wossner, Asso etc etc.
Scooterdude
Postby ULC Soulagent » Sun Nov 24, 2019 4:37 pm
Mb on the left
Casa on the right
ULC Soulagent
Postby Scooterdude » Sun Nov 24, 2019 5:12 pm
ULC Soulagent wrote:Image
Mb on the left
Casa on the right
Good marketing trick though, forcing you to buy a new head you otherwise wouldn’t need . :?
Scooterdude
Postby al pushpak » Sun Nov 24, 2019 5:19 pm
Thanks for the putting up the pics, I can clearly see there is a big difference!
al pushpak
Postby superhooper » Sun Nov 24, 2019 9:56 pm
For your info. Just replaced a mb piston for a Harry Barlow piston in my TS1. Grade A in a Grade B Barrel.
Super
superhooper
Postby Fast n Furious » Mon Nov 25, 2019 3:53 am
superhooper wrote:For your info. Just replaced a mb piston for a Harry Barlow piston in my TS1. Grade A in a Grade B Barrel.
Super
This can happen, especially with some forged piston makes.
Postby Knowledge » Mon Nov 25, 2019 2:24 pm
Harry Barlow (Pro-porting) does a line in replacement TS1 pistons.
it might be worth contacting him.
Postby ian i.o.w » Mon Nov 25, 2019 8:04 pm
I have used them all fine for me ,as been said in standard untuned barrels and Ron does state this on adverts I have seen , in fact I just purchased a couple for spares as he has them on offer
ian i.o.w
Postby ROClarke » Wed Nov 27, 2019 9:58 pm
I am about to order a casa black line piston for my TS1 in size B, is this the same size as my existing Asso piston?
ROClarke
Postby Fast n Furious » Wed Nov 27, 2019 11:47 pm
ROClarke wrote:I am about to order a casa black line piston for my TS1 in size B, is this the same size as my existing Asso piston?
It should be.
Always best to measure it up and make sure.
Postby Scooterdude » Thu Nov 28, 2019 6:58 am
If you use the casa black line piston you will need the matching casa head that goes with it as they’re a flat top rather than the standard 7mm dome height like the Asso.
Scooterdude
Postby ROClarke » Thu Nov 28, 2019 6:23 pm
Hi F.
I was thinking of changing to a casa head for better cooling qualities anyway.
Cheers.
ROClarke
Postby Norrie Bodge » Thu Nov 28, 2019 7:57 pm
Hi F.
Cheers.
I enquired about these radiale heads a while back
& they told me they do them in same profile as a std type asso piston
https://www.riminilambrettacentre.com/e ... inale.html
Norrie Bodge
Postby Norrie Bodge » Thu Nov 28, 2019 9:22 pm
Get ya Radiale head ordered 2mora mate great savings tbh
Norrie Bodge
Postby ROClarke » Sat Nov 30, 2019 11:01 am
Norrie Bodge wrote:Get ya Radiale head ordered 2mora mate great savings tbh
Saved 30% yesterday on Blackline Head and Piston.
But,got sucked in and bought the casa varitronic fan as it was reduced as well which I was not intending to buy :lol:
ROClarke
Postby ROClarke » Sat Nov 30, 2019 8:27 pm
Will I need to do anything to the bore,bearing in mind it is nicasil ?
ROClarke
Postby dscscotty » Sun Dec 01, 2019 8:36 am
As with all replacement pistons in any bore irrespective whether its the correct piston, i:e original piston for the cylinder the the piston to bore clearance should be checked
Postby HxPaul » Mon Dec 02, 2019 11:05 am
Postby Simon_T » Tue Dec 03, 2019 12:21 pm
al pushpak wrote:Hi, I want replace the asso piston in my ts1 kit & was wondering if anyone has used one of the above pistons, my kit is totally standard with no tuning .I run it one of Ron Moss ex box exhausts & a 30mm phbh . I was going to purchase a wossner piston as a replacement but they are out of stock everywhere so was considering one of these. thanks for any info ;)
what's your jetting with that carb and pipe Al .. ?
Simon_T
Postby al pushpak » Tue Dec 03, 2019 1:13 pm
hi Simon, off the top of my head its as follows - main jet 137/or maybe 138?, pilot 55, needle float jet 300, choke 70, atomiser av 266 , slide 40, slide needle x13 top clip, running through a foam remote filter. hope this helps ;)
al pushpak
Users browsing this forum: No registered users and 15 guests
