Mugello manifold
Mugello manifold
Postby Wack » Sun Nov 24, 2019 3:52 pm
I was hoping to use a TV175 manifold with a solid mount PHBL 24 in a Mugello 198 kit but find that the carb won’t go on as the bowl fouls on the head cowl and engine mount. A standard carb goes on just but the fuel banjo touches the mount. Anyone recommend a solid mount manifold that would fit with the PHBL. Machining the stub to size is not a problem.A lesson learned is never use a Mugello again as a simple bolt on kit!
Re: Mugello manifold
Postby Scooterdude » Sun Nov 24, 2019 4:25 pm
Hi yes, just done one for someone PHBL 25 onto a Mugello 198 i used an MB manifold as this allowed good clearance on both the float bowl and banjo.
I was also able to use a modified air box with MB mesh filter but used the casa bellows which give just enough flex to allow everything to line up nicely. (Scootopia ones are to stiff and the cheap ones to floppy).
Sorry just noticed you said solid mount, the one i did was a rubber mount.
Hope this helps
Scooterdude
Postby Wack » Sun Nov 24, 2019 6:13 pm
Thanks for the reply, would you have a link for the manifold please?
Postby Scooterdude » Sun Nov 24, 2019 8:45 pm
Scooterdude
Postby vegansydney » Mon Nov 25, 2019 1:07 am
Jet200 make a fantastic manifold for clamp-on PHBL carbs. I used one for many years, and can't fault them. I believe RLC also make a manifold for clamp-on Dell'Ortos, but can't remember if it's for the PHBL or PHBH.
vegansydney
Postby Wack » Mon Nov 25, 2019 5:15 pm
Thanks for the replies chaps, the Jet 200 one looks perfect shame they’re in the US.
Postby Adam_Winstone » Thu Nov 28, 2019 3:42 pm
Yep, looks like a decent product.
Postby Wack » Fri Nov 29, 2019 8:44 pm
Ended up with a cheap cast manifold similar to the Scoot RS one,then cut the stub off and welded a turned one on .Now carb fits perfect.Thanks for the advice all.
Postby bsso78 » Fri Nov 29, 2019 9:21 pm
I had the same problem with a standard manifold but found that a TV175 one gave me enough clearance. Odd one that as yours didn’t.
bsso78
Postby vegansydney » Tue Dec 03, 2019 1:49 am
Wack wrote:Thanks for the replies chaps, the Jet 200 one looks perfect shame they’re in the US.
Postage would probably be faster than some UK dealers :roll:
vegansydney
Users browsing this forum: Bing [Bot], Nudger and 11 guests
