Hello. Have been happily running in my Li - just 150 klicks to go!
However.. my carello rear light blew yesterday, not a big problem as I carry a spare, but when the rear blew the brake light then also didn't work unless the bottom on/off switch was put into the middle position (the one that is not really a position and only for transition between on/off to prevent bulb blowing).
12v casatronic, non battery, wired to a late Li loom so as to use the later three <edit> wire</edit> brake pedal.
Also rear light is always on, not a problem as I always have lights on, but that might be a dodgy switch.
is it normal that the brake light stops working when the rear blows?
Thank you. Andie
