Lambretta rectifier
Lambretta rectifier
Postby Stevepshipley » Thu Dec 19, 2019 5:08 pm
Hi fellas,
Is there an easy way to test a Lambretta rectifier is doing what it should? I.e. putting out 6 volts A/C whilst also putting out D/C to charge the battery?
Restoring a S2 TV2 and I’m trying to keep it original but want to make sure the rectifier works before I go down the battery route. My multimeter just jumps all over the place when the engines running and I’m trying to get a reading.
Cheers steve
Stevepshipley
Re: Lambretta rectifier
Postby dickie » Fri Dec 20, 2019 11:51 am
Digital meters can be a pain when you're measuring anything that fluctuates.
Most have a 'range' button which stop it from auto-ranging; I find this very useful.
Or use an old fashioned moving coil analogue meter.
Postby Stevepshipley » Fri Dec 27, 2019 11:18 am
Thanks D.
Ordered a cheap analogue meter to try
Cheers steve
Stevepshipley
Users browsing this forum: Google [Bot] and 16 guests
