by Psychedelicropcircle » Fri Feb 14, 2020 2:40 pm
Does someone have the spring for the kickstart piston & Layshaft spring to hand for measuring purposes?
The spring I am trying to get into the layshaft is 35.5mm and a complete basterd
Much obliged in advance
Scott.
by Scooterdude » Fri Feb 14, 2020 2:47 pm
Got one of those MB super silly strong ones that measures 25.5 mm and a standard one that measures 23mm. Hope this helps.
Scooterdude
by Psychedelicropcircle » Fri Feb 14, 2020 3:07 pm
25mm lol it’s defo a KS spring then
bought long ago no idea where but it was all in the one bag bloody scooter dealers
by Scooterdude » Fri Feb 14, 2020 3:31 pm
I wouldn’t recommend the MB one either they’re atrocious.
Scooterdude
by HxPaul » Sat Feb 15, 2020 10:21 am
If its the one spring with bearings on either side they are a bastard to fit.Putting them in a bag to fit them is the best idea,that way if the bearings come out they will still be in the bag and not rolling around on the floor.
by Kev Fox » Sat Feb 15, 2020 11:37 am
HxPaul wrote:If its the one spring with bearings on either side they are a bastard to fit.Putting them in a bag to fit them is the best idea,that way if the bearings come out they will still be in the bag and not rolling around on the floor.
https://www.facebook.com/groups/1669987 ... 342847291/This is a link to a facebook post about fitting the spring & bearings. This aint a bad idea for anyone that struggles.
Kev Fox
by Scooterdude » Sat Feb 15, 2020 12:12 pm
I use an old selector and squeeze the two together I found this is easiest way.
Scooterdude
by dscscotty » Sat Feb 15, 2020 2:47 pm
CASA Selector (Blue) are great,not to heavy on gear change, great for 5 speeds as well which do tend to need a higher loaded spring to stop any issues, particularly to stay in 5th
by bookertmgs1 » Sun Feb 16, 2020 9:23 am
Scooterdude wrote:I use an old selector and squeeze the two together I found this is easiest way.
Agree - this is the simplest way I’ve used. If you search this forum there is a full thread about easiest way and a video to demonstrate
bookertmgs1
by HxPaul » Sun Feb 16, 2020 10:36 am
bookertmgs1 wrote:Scooterdude wrote:I use an old selector and squeeze the two together I found this is easiest way.
The trouble with that method is,you need two selectors,not everyone has got two(one new one and one old one)
by Psychedelicropcircle » Sun Feb 16, 2020 2:31 pm
It’s been years since I done one ( with exception to a cyclone box 3 yr ago or so, can’t remember that one) One previous to that I pushed in a ball bearing with each hand & wapped the head on the sliding dog into place! My forehead is pretty sore after trying with a 35mm spring
