Rear Light - 3 x festoon bulb type
Postby Granty » Fri Apr 17, 2020 10:29 pm
Got a replacement rear light bulb holder, it's the one with 3 festoon bulbs required, 1 for the light & 2 for the brake I think. Anyone know what length of festoon bulb fits in this? I got 3 festoon bulbs from the same supplier but they're massive, 38mm in length, not sure what size they should be for the bulb holder. Anyone know? - cheers G
Granty
Re: Rear Light - 3 x festoon bulb type
Postby landybretta » Sat Apr 18, 2020 9:59 am
I think they are 30mm but why not give the supplier whose photo you have posted a call to confirm. I use them a lot and they are very helpful.
landybretta
Postby drivera » Sat Apr 18, 2020 10:54 am
Scooter Restorations sell 30mm and 38mm festoons , top tip use 6v for the brake light and they are nice and bright :D
drivera
Postby Granty » Sat Apr 18, 2020 2:25 pm
landybretta wrote:I think they are 30mm but why not give the supplier whose photo you have posted a call to confirm. I use them a lot and they are very helpful.
Will do, dropped them an email and will follow up, just wondered if there was an obvious one here. Thanks, G
Granty
Postby Andyf » Sat Apr 18, 2020 6:54 pm
drivera wrote:Scooter Restorations sell 30mm and 38mm festoons , top tip use 6v for the brake light and they are nice and bright :D
there ought to be a 'smilie' for this - could you explain this for us dummies please?
Andyf
Postby drivera » Sun Apr 19, 2020 7:29 am
Basically your putting twice the power through the bulb so it will be brighter , it's ok for brake lights as they are only on for short bursts but if you used a 6v as a tail light it would blow quite quickly
drivera
Postby Andyf » Sun Apr 26, 2020 8:29 pm
were the early models 12V?
Andyf
