by Simon_T » Sun Jun 08, 2014 6:22 pm
Hi I have a problem with the gearbox on my newly built ts1
Changes up ok but on the way back down through the gears when I change from 2nd to 1st it makes a racing noise or rattling noise.
Any ideas..?
Simon_T
by Knowledge » Sun Jun 08, 2014 6:25 pm
Just to clarify, is it making noise while it is in neutral as it changes from 2nd to 1st?
What happens if you linger in neutral? Any noise?
Presumably, it doesn't make the same noise as you change from 1st to 2nd?
by Simon_T » Sun Jun 08, 2014 6:39 pm
No noise in neutral as far as I'm aware from 2nd to 1st
Simon_T
by Simon_T » Sun Jun 08, 2014 6:41 pm
Knowledge wrote:Just to clarify, is it making noise while it is in neutral as it changes from 2nd to 1st?
No noise when changing 1st to 2nd
Simon_T
by Simon_T » Sun Jun 08, 2014 10:45 pm
Knowledge I've been out again tonight on the scoot and it is possible it's making the noise when in neautral changing up and down 1st and 2nd
Simon_T
by Simon_T » Sun Jun 15, 2014 9:26 pm
Problem solved.. Whoever put the gearbox in used the wrong gear with the wrong amount of teeth.
Fitted a new gear and instantly problem solved.
Noise gone and 1st is now easy to select
Simon_T
