Atf
Atf
Postby missing lynx » Thu Jul 16, 2020 10:31 am
I've read some are using atf. I have two questions, what is the advantage and are the different types, grades, if so which one to use?
Re: Atf
Postby Toddy » Thu Jul 16, 2020 10:46 am
ATF ?
Re: Atf
Postby neily03 » Thu Jul 16, 2020 10:50 am
Toddy wrote:ATF ?
Automatic transmission fluid.
neily03
Re: Atf
Postby L111amo » Thu Jul 16, 2020 6:10 pm
Think I was put on here somewhere , thin oil but grippy I suppose , as the older type autos used multi plates/ belts
L111amo
Re: Atf
Postby Warkton Tornado No.1 » Thu Jul 16, 2020 8:46 pm
Probably me :D
I"ve been using Dexron III since 2013 when I built a motorcycle alloy six plate clutch with interchangeable rear sprockets (46, possibly 45 minimum) for race use. It got tested on a bed wetter's* dyno prior to track use & the whole thing was an instant success, though racing has been side lined.
However, I tried it in a slipping road engine scootRS six plater that I had been nursing & it cured it, so been using & fitting it to other engines since.
Not suitable for those prejudiced die yards that follow the crowd, but their loss ;)
* Obviously, I do bear grudges.....
Re: Atf
Postby Norrie Bodge » Thu Jul 16, 2020 8:53 pm
Warkton Tornado No.1 wrote:Probably me :D
As in this? https://www.ebay.co.uk/itm/303138950239
Norrie Bodge
Re: Atf
Postby Warkton Tornado No.1 » Fri Jul 17, 2020 2:37 am
Any Dexron III is suitable. I got mine from Europarts, though one litre is ample for one engine....
Users browsing this forum: Baidu [Spider] and 13 guests
