Storkfoot wrote:I very much suspect not. I wouldn’t risk it on such an important part. I filed it flat and it now needs to be very carefully drilled and tapped.
Warkton Tornado No.1 wrote:I had a quick shufty @ an actuator in a spare disc brake, & reckon an M8 would do it. I also think there might be getting on for 5 mm space beneath the 'I' cap, so room for the head of a screw, though my favourite would be to use a Countersunk high tensile screw with a GPW.
vegansydney wrote:Warkton Tornado No.1 wrote:I had a quick shufty @ an actuator in a spare disc brake, & reckon an M8 would do it. I also think there might be getting on for 5 mm space beneath the 'I' cap, so room for the head of a screw, though my favourite would be to use a Countersunk high tensile screw with a GPW.
As per the photo I posted earlier on this thread, I've been running a few rebuilt actuators for over a decade, all are fitted with M6 x 20mm high tensile button heads. All are holding up fine after 10+ years of regular use (as are several others fitted in scooters belonging to friends) and there is plenty of room to fit the 'i' cap.
Warkton Tornado No.1 wrote:There are two school's of thought about the positioning of the circlip ears, but my own take is that the circlip, being a spring, is best placed with the ears placed where they can exert pressure. In the groove, rather than fresh air. That way, it can best conform to the shape of the groove with less tendency for any voids & be as fully supportive as possible.
Do you fit clutch circlip said the same way?
gaz_powell wrote:Cracking job Paul, it's not a run of the mill job, I've never tackled stripped/rebuilding one, however having now seen it done, I would.
Good to have shared the progress.
Storkfoot wrote:Many thanks to vegansydney who led the way. Cheers, Benji
Users browsing this forum: Majestic-12 [Bot] and 10 guests
