missing lynx wrote:Serveta lynx wiring
Warkton Tornado No.1 wrote:Working on somebody else's engine supplied with the bike that requires far more work than foreseen due to bad crankshafts, cross-threaded spark plugs, stripped threads, bodges, Rolon chains, MB plastic cage rear hub bearings, no gearbox oil etc. Being told that it runs but, when questioned on the subject, finding out that it never did.
Then being unable to simply disregard all of the life threatening issues prior to testing. Seriously: broken rims, missing hub nuts, mis-fitted brake cable clevises, broken front brake levers, too short a rear damper etc etc
Storkfoot wrote:Warkton Tornado No.1 wrote:Working on somebody else's engine supplied with the bike that requires far more work than foreseen due to bad crankshafts, cross-threaded spark plugs, stripped threads, bodges, Rolon chains, MB plastic cage rear hub bearings, no gearbox oil etc. Being told that it runs but, when questioned on the subject, finding out that it never did.
A bit harsh, WT. I did jet wash the casing for you first
gaz_powell wrote:Any of those.... "five minute" jobs......
