rossclark wrote:Isn't the issue with EP to do with the phosphor bronze bushes?
ToBoldlyGo wrote:We all know the difference between semi and synthetic oils, but gearbox oil baffles me. I have no idea what the various grades mean. I tend to use Silkolene Medium Gear oil myself, and find it perfectly okay. But it came up the other day in relation to ST90, and it occurred to me that I don't actually know what the grades mean in the same way I would an engine oil. I know it's a little thinner, but that's about it. Can somebody explain it all?
burnside wrote:All I know is you need to use non-EP gear oil as EP additives don't play well with cork plates, and the number relates to the viscosity, i.e. the higher the number the higher the viscosity
Fast n Furious wrote:It's like I mentioned earlier in this post. The lambretta uses a 90 weight Gear oil wheras the Vethspa uses a 30 weight engine oil. The viscosity is very similar..
shamrockexpress wrote:Fast n Furious wrote:It's like I mentioned earlier in this post. The lambretta uses a 90 weight Gear oil wheras the Vethspa uses a 30 weight engine oil. The viscosity is very similar..
so Why do you need a 90????
Users browsing this forum: Google [Bot] and 18 guests
