Engine water
Engine water
Postby Freight10 » Mon Aug 24, 2020 5:39 pm
Hi all, recently brought a project scooter, anyway now I've stripped it all down I thought I'd have a go at the engine, so I drained the oil first and just rusty water came out..
Here are some pics once I took the casing off, not pretty, cant understand how it got like this, particularly as to my knowledge it's been stored in my garage a year and yet it's still wet..
Freight10
Re: Engine water
Postby coaster » Mon Aug 24, 2020 8:42 pm
Was it a runner when you aquired it? Rust and corrosion like that suggest months or years of wet storage I would think :?
Re: Engine water
Postby dickie » Tue Aug 25, 2020 9:21 am
Probably hasn't done much damage to the casing, but the hardened surfaces on gears may well have suffered.
Re: Engine water
Postby Freight10 » Tue Aug 25, 2020 10:29 am
No it wasnt running, but hopefully it will be soon, I'm not overly fussed, I have a new 198 kit and new 150 gearbox for it. My main concern was how it got in, dont want it happening again once rebuilt..
Freight10
Re: Engine water
Postby Hat » Tue Aug 25, 2020 11:34 am
Condensation from an unheated garage?
Hat
Re: Engine water
Postby rossclark » Tue Aug 25, 2020 11:46 pm
The breather, perished seals on clutch or gear shafts?
Re: Engine water
Postby Freight10 » Wed Aug 26, 2020 8:28 am
That doesn't sound to bad then, I'm obviously replacing all the bearings and seals as part of the rebuild.
Freight10
Re: Engine water
Postby bookertmgs1 » Wed Aug 26, 2020 9:21 am
wouldnt worry too much - if you rebuild right it will be fine
i'd get it vapor blasted - will come up like new. If there is any structural damage (cracks etc) they will be more easily visable
bookertmgs1
Re: Engine water
Postby Fast n Furious » Wed Aug 26, 2020 10:22 pm
Just remove most of the muck with a degreasant first before taking to the vapour blasters.
Vapour blasting is worth every penny, which you will appreciate so much when putting it all back together. :D
Re: Engine water
Postby Freight10 » Thu Aug 27, 2020 2:18 pm
Thanks both, I intend to get it vapour blasted, had one done a few years back, as you say F&F, worth every penny.
Freight10
Re: Engine water
Postby davla » Thu Aug 27, 2020 3:28 pm
Vapour blasting seems to make the casing porous in my experience. Best to just give a good clean up with gunk imo or get it blasted with something less harsh.
davla
Re: Engine water
Postby Toddy » Thu Aug 27, 2020 4:01 pm
davla wrote:Vapour blasting seems to make the casing porous in my experience. Best to just give a good clean up with gunk imo or get it blasted with something less harsh.
Really ? had a few done never had any issues
Re: Engine water
Postby hullygully » Sun Aug 30, 2020 1:02 pm
ditto 8-)
Users browsing this forum: Bing [Bot] and 15 guests
