MickYork wrote:woodruff key sheared....maybe ?
MK Monty wrote:Very easy to shear it even a new one. Has it run OK and just started to backfire. I have sheared mine by not doing the flywheel up tight while strobing it up. It’s a clear sign the timing is out.next you look at stator pick up and does it line up with the flywheel. Lots of combinations of parts being supplied these days.
coaster wrote:What does the compression feel like and is it a sharp backfire or more like a wet fart. Low compression can result in a wet bacfire as the gasses escape past the rings
Toddy wrote:Head Gasket / Seal ??
rodney wrote:Hi, just rebuilt a li150 series 2. Got the 12v kit working correctly now and all I get is a backfire now and again when kicking over. It won’t fire up, any suggestions? Thanks
rodney wrote:Backfire has gone, checked woodruff key and reset timing now I get nothing at all. Got spark and fuel but she just won’t fire up. Thanks for everyone’s help
Users browsing this forum: No registered users and 56 guests
