Straight frame Check?
Need specific detail for a particular model, or just found something strange and interesting and want to know if its original. All attention to detail seekers report here!
Strict no chatter
Postby jdevane5 » Fri Dec 04, 2020 12:18 pm
Is there a way to check your frame is straight before a rebuild? Something that can be done at home?
I'm thinking of a check say similar to a vehicle with plum lines and chalk , measurement between points etc.
Anyone ever come across a method of checking other them the obvious visual check, welding, bent steel etc.
jdevane5
Re: Straight frame Check?
Postby Storkfoot » Sat Dec 05, 2020 11:45 am
If it is an LI frame, there are a few jigs around the country and some measurements you can check at home with a tape measure and a long straight length of metal.
What frame do you have?
Postby dickie » Sat Dec 05, 2020 9:16 pm
The early parts of this thread might help
http://www.ilambretta.co.uk/forum/viewtopic.php?f=19&t=11475
Postby jdevane5 » Sat Dec 05, 2020 11:45 pm
Thanks the thread, really useful.
I have two Series 3 to rebuild, starting in Jan.
JD
jdevane5
Postby dickie » Sun Dec 06, 2020 8:59 am
jdevane5 wrote:Thanks the thread, really useful.
JD
Nice, hope you're going to share your progress in the forum. It's always interesting seeing another lambretta coming back to life
Return to Anorak's Corner
