by TurboTrev » Sat Dec 12, 2020 10:06 pm
I've got two original Veglia Series 3 speedos. I think one is MPH and one is KPH. Looking at the mechanism, can anyone say definitely which one is which? Thanks.
TurboTrev
by Fast n Furious » Sun Dec 13, 2020 1:31 am
Series 3 clocks variants had a fullscale deflection indicating
60MPH (100kph) typical for a 125
70MPH (120kph) typical for a 150 / 175
90MPH (140kph) typical for a 200
The speedo cable turns at 1610 revolutions per mile (1000 revolutions per kilometer) for all machines. So the internal gearing ratio of the clock mech is different for each full scale.
Nothing to do with it being kph or mph.
hopefully an adult will be along shortly to inform you which of the 3 you have.
by HxPaul » Sun Dec 13, 2020 9:31 am
Use a battery powered drill in reverse,which ever is the fastest is the kph one.
by TurboTrev » Sun Dec 13, 2020 10:33 am
^^ Thanks for your replies. I might be wrong, but the needle can be removed to calibrate speed, my query is more about the mileometer bit and whether it's recording miles or kilometers.
TurboTrev
by missing lynx » Sun Dec 13, 2020 2:30 pm
I would have thought the larger cog one was the mph one as the revolution would make the numbers move slower than the smaller cog
by ToBoldlyGo » Sun Dec 13, 2020 5:36 pm
I think you're right Missing Lynx. That's what I've found when I've taken them to pieces.
ToBoldlyGo
by Fast n Furious » Mon Dec 14, 2020 2:25 am
Turn the speedo drive 1000 times. If the odometer moves on by 1 Km then it's foreign.
If it takes 1610 turns to move it on by 1 digit then it's domestic.
by TurboTrev » Tue Dec 15, 2020 6:19 pm
^^^ Thanks for your replies.
TurboTrev
by Leotech » Sat Dec 19, 2020 5:50 pm
Black is miles, no colour is KM,
The only difference is the black upright drive and the amount of teeth on the corresponding gear on the end of the milometer.
KM one had 16 teeth and the Miles one 22 I think.
Leotech
by TurboTrev » Mon Dec 21, 2020 8:06 pm
Leotech wrote:Black is miles, no colour is KM,
Many thanks for that. Do you know if a KPH upright drive/corresponding gear can be removed and replaced with their MPH counterparts?
TurboTrev
by vegansydney » Thu Dec 24, 2020 9:18 pm
One on left is MPH. The black drive and cog is the telltale sign. They can be converted between MPH and KM by swapping these two parts, at least on Vegila speedos (uncertain about CEV speedos).
vegansydney
by TurboTrev » Fri Dec 25, 2020 10:09 pm
vegansydney wrote:One on left is MPH. The black drive and cog is the telltale sign. They can be converted between MPH and KM by swapping these two parts, at least on Vegila speedos (uncertain about CEV speedos).
Good to know, thanks.
TurboTrev
Users browsing this forum: Bing [Bot] and 12 guests
