Can anyone give me the size of the frame tube where the forks go on a GP.
I've aquired a Spanish series 80 frame and want to reduce it to take GP forks
ULC Soulagent wrote:Spanish is 40 inches
Gp is 37 inches
gizmo wrote:Last one I had done by Paul at Oiltek i think he took about 28 mm off fork tube but it was an Italian Li. He also cut it out of the middle and welded a tube inside. This for one reason retains the lip at the top to seat the fork bearing. Same with forks, taken out of middle. Good look. Think Knowledge did a post on this at some point.
Knowledge wrote:ULC Soulagent wrote:Spanish is 40 inches
Gp is 37 inches
Do you mean centimetres rather than inches?
can't beat a bitsa. Probably most on the road aregaz_powell wrote:I've not got the frame yet, so nowhere near cutting anything yet.
Frame will be jigged, so will getting the cut done then and sort out the steering lock plate.
I ve got the GP forks, leggies and headset bottom.
Thanks for the comments today..... I'll make sure I don't get me inches and centimeters mixed up...![]()
Another bitsa on the way
Users browsing this forum: Google [Bot] and 16 guests
