TV Crank
TV Crank
Postby drivera » Mon Mar 29, 2021 12:03 pm
Trying to fix a mates TV175 and its apparent that his crank is knackered around the keyway , thinking of upgrading to a GP crank so question is does anyone sell a GP crank with a TV conrod or would it have to be custom made ?
drivera
Re: TV Crank
Postby vegansydney » Mon Mar 29, 2021 1:02 pm
There are a few companies making quality 58 x 116 GP tapered cranks, including AF, Casa Performance and SIP.
vegansydney
Re: TV Crank
Postby tim_mason » Mon Mar 29, 2021 1:54 pm
Buzzsolomoto used to sell them.
tim_mason
Re: TV Crank
Postby ULC Soulagent » Mon Mar 29, 2021 1:57 pm
Value for money would be the Tameni offering, next would be sip, then bgm, after that u need a small bank loan ;)
ULC Soulagent
Re: TV Crank
Postby Warkton Tornado No.1 » Mon Mar 29, 2021 2:58 pm
If the TV 175 engine is completely standard & the intention is to keep it that way, then by exchanging the OEM crankshaft (unique to the 175) you will alter the balance factor.
IMO & experience the TV 175 was one of the most delightful engines produced because of that. That would explain why Innocenti persevered with it, rather than 'rationalise' production & fit the shorter con rod Li type.
If not a new replacement, I would suggest place a WANTED on this site for a used one before committing to any alternative ;)
Re: TV Crank
Postby Cgt75b » Mon Mar 29, 2021 5:43 pm
Harry Barlow of Pro porting fame knocked me yan up,
Give him a bell, he maybe able to help
Cgt75b.
Re: TV Crank
Postby Leotech » Mon Mar 29, 2021 7:16 pm
I have just done exactly that to my standard TV175.
I got a GP taper crank off Martin at Just Lambretta.
I went to 116 x 60 stroke too and in my opinion the TV performs even better than it did with the 116 x 58 crank that is standard. It has lost none of its low down torque but has gained a bit more on top. 1mm base gasket and a 1mm head gasket with 1.2 squish. Love it
Leotech
Re: TV Crank
Postby Toddy » Mon Mar 29, 2021 10:19 pm
drivera wrote:Trying to fix a mates TV175 and its apparent that his crank is knackered around the keyway , thinking of upgrading to a GP crank so question is does anyone sell a GP crank with a TV conrod or would it have to be custom made ?
Speak to Scotty on here he’s good with cranks ;)
Re: TV Crank
Postby Fast n Furious » Tue Mar 30, 2021 1:26 am
You should also consider a new flywheel if the taper surface has been scored badly.
Re: TV Crank
Postby GExS » Sat Apr 03, 2021 3:28 pm
Look around and I’m sure you can find some remade 58x116 ones. I run my TV175 with the original crank with a lighter electronic flywheel(the only upgrade) so I’m not worried about the tapper snapping.
TV cylinders with Suzuki TS185 pistons are a very easy conversion if you use a 60x115 crank and if you want to go in that direction.
GExS
