Scootopia clubman
Scootopia clubman
Postby steveg » Sun Mar 28, 2021 7:32 pm
I need to replace an early version BGM on a S2 with a 186 mugello and 26mm PHBH.
I'm thinking of trying the Scootopia 42mm clubman, anyone got experience of these? Would you recommend?
Cheers Steve
steveg
Re: Scootopia clubman
Postby Toddy » Sun Mar 28, 2021 8:34 pm
Fitted a few on mugellos good quality and fit and performance is good on the ones I’ve fitted
Postby Scooterslag » Sun Mar 28, 2021 11:04 pm
I fitted one to a mates Jet 200 and went well with a up-jet on the standard 20mm delly . Nice fit and quality for the money .
Postby Tractorman » Mon Mar 29, 2021 8:44 am
Very good exhausts and they fit without the fettling that comes with many other makes.
Postby ULC Soulagent » Mon Mar 29, 2021 2:18 pm
Great pipe and value for the money. Finding a dealer who has them in stock is the problem :(
ULC Soulagent
Postby hullygully » Mon Mar 29, 2021 5:46 pm
I fitted one onto a mates SX150, fitted like a glove
Postby steveg » Mon Mar 29, 2021 7:55 pm
Performance wise are they more AF or BGM?
steveg
Postby Toddy » Mon Mar 29, 2021 10:21 pm
steveg wrote:Performance wise are they more AF or BGM?
On the ones I did it compared performance wise more with the BGM
Postby steveg » Tue Mar 30, 2021 6:40 am
Sounds good
steveg
Postby landybretta » Tue Mar 30, 2021 9:34 am
ULC Soulagent wrote:Great pipe and value for the money. Finding a dealer who has them in stock is the problem :(
Scootopia website says out of stock but i have just ordered one from their fleapay shop.
TASS also appear to have them.
landybretta
Postby dickie » Tue Mar 30, 2021 11:19 am
I've never had a scootopia on the dyno, but I did with an ancillotti which it is copied from. I changed the ancillotti to a bgm clubman, but notably, also went from 25phbl to 30phbh at the same time, so not a direct comparison. Power went from 9.5bhp to 13bhp. Lost a little bottom end and felt slightly more top-endy, as if it were a very low end expansion.
The scootopia is a 42mm header and the bgm 48mm. Larger headers tend to work better at higher rpms, all things being equal.
Postby ToBoldlyGo » Thu Apr 01, 2021 5:54 pm
Get one. I doubt you'll regret it.
ToBoldlyGo
Postby steveg » Thu Apr 01, 2021 9:10 pm
Thanks to everyone for the feedback.
Largely very positive and I have bought one off their Ebay shop.
Should be here tomorrow I hope.
Will also have the BGM repaired, only the baffle plate come away but always nice to get something new.
steveg
Postby steveg » Sun Apr 04, 2021 10:26 pm
Picked up the scootopia pipe Friday.
First impressions prior to fitting, feels a little lightweight, particularly compared to the BGM pipes, paint finish not great (will blow over with VHT paint) welding around manifold stub not good, possibly even porous, so a friend is going to grind it back and reweld. On the plus side it comes with everything there to fit it (gasket, spring puller etc) which not all pipes do.
Hopefully it will fit well and performance will be decent enough.
steveg
Users browsing this forum: steveg and 24 guests
