Warkton Tornado No.1 wrote:Ha!![]()
Just for 'balance' (as in " you pays your money & makes your choice") when it comes to ease of use & cost:
https://www.toolstation.com/connector-nut/p29740
So, £1.39 for ten off.
M7 tap (most of us will already possess) but, say, about four quid...
Lockwire or some stripped copper wire.
Change from twelve pounds to do five engines.
Hmmmm. I think i'll 'stick'
A good compromise ould be your re-tapped and cross drilled nuts but using an R clip instead of the lock wire, no need to carry wire, cutters and pliers
