by AndyVee » Fri May 28, 2021 1:53 pm
Hi all, can anyone point me in the right direction as to how to strip down an S3 ignition switch (Or is it a sealed unit ?). I just want to check I don't have a simple loose wire or something before I spend £40+ on a new one and cant find anything on the web indicating how to do this . . . . . Thanks.
AndyVee
by Toddy » Fri May 28, 2021 2:36 pm
AndyVee wrote:Hi all, can anyone point me in the right direction as to how to strip down an S3 ignition switch (Or is it a sealed unit ?). I just want to check I don't have a simple loose wire or something before I spend £40+ on a new one and cant find anything on the web indicating how to do this . . . . . Thanks.
The wires are usually soldered at the back of the unit you can see these by taking the rubber boot off the back
by coaster » Fri May 28, 2021 5:17 pm
Send it to Jem Booth for an overhaul, he is the go to expert
