Loss of power
Loss of power
Postby Specialcase » Sat Aug 14, 2021 10:37 pm
Hi all
Riding my BGM RT195 VAPE & 25mm Dell’Orto the power reduces rapidly (almost dies) as I get to full chat, it almost cuts out until I ease off then it picks up again this is repeated all the time.
Is there a simple solution that I could sort out with my limited knowledge & tool kit (a Swiss Army Knife & my MB plug spanner)?
TIA
Spl
Specialcase
Re: Loss of power
Postby dscscotty » Sat Aug 14, 2021 10:54 pm
Presuming the jetting is correct it sounds like its fuel starving, make sure you have adequate fuel flow from tap, fuel line and the fuel/needle flow valve within the carb is big enough, also check the fuel cap is breathing, as it could be vacuumimg
Re: Loss of power
Postby dickie » Sun Aug 15, 2021 12:33 am
I once had this same issue caused by fitting the baffle in the float bowl upside down.
Ran fine unless I held WOT for more than a few seconds.
Re: Loss of power
Postby Covboy » Sun Aug 15, 2021 10:16 am
Dickie - out of interest which way up is the correct way for the baffle?
Re: Loss of power
Postby coaster » Sun Aug 15, 2021 7:09 pm
Covboy wrote:Dickie - out of interest which way up is the correct way for the baffle?
The open side faces down
Re: Loss of power
Postby Fast n Furious » Sun Aug 15, 2021 9:10 pm
Specialcase wrote:Hi all
TIA
Spl
Is your engine a "new build" or the bike a recent aquisition or did it used to run ok but has recently developed these symptoms?
Users browsing this forum: No registered users and 15 guests
