Series 3 LI rear brake set up
Postby ianmoran » Fri Nov 12, 2021 6:34 pm
Rear brake cam on series 3. Should it have a washer inside and outside the engine casing, with the o ring and circlip on the outside?
I dismantled this to service it and only one washer appeared. Then I read it should have 2 ?
Cheers,
Ian
ianmoran
Re: Series 3 LI rear brake set up
Postby Wack » Fri Nov 12, 2021 8:12 pm
One shim on the inside then O ring under the lever.You will find it's hard to fit another shim with the O ring( if using a clutch shaft one) as near impossible to fit the circlip.
Postby ianmoran » Sun Nov 14, 2021 10:04 pm
Cheers, Wack
ianmoran
Users browsing this forum: No registered users and 9 guests
