GT186 manifold - carb fouling engine mount
Re: GT186 manifold - carb fouling engine mount
Postby coaster » Thu Oct 14, 2021 9:33 am
Storkfoot wrote:....From experience on the road, I can vouch for the fact that this issue does not present itself with this barrel :( :)
I can vouch that you were very 'slick' at doing that by the time we got back from Italy ;)
Postby Storkfoot » Thu Oct 14, 2021 1:35 pm
It was a pity I never noticed the bent exhaust stud at Lake Como. If I had, the second strip down in France would not have been needed. Such is life :D
Postby Storkfoot » Mon Nov 15, 2021 10:26 pm
Vegansydney, I thought I’d give you an update on the jetting. This is with a filter and a Ron Moss Avanti box exhaust now.
Atomiser Q0, needle 4DH7 2nd clip and slide 3.0. Main 175, pilot 17.5.
I haven’t done too many miles, mainly as I haven’t got any legshields fitted, but I am pretty sure that is very close. Perhaps the main may change 5 either way.
Postby vegansydney » Tue Nov 16, 2021 2:54 am
Storkfoot wrote:Vegansydney, I thought I’d give you an update on the jetting. This is with a filter and a Ron Moss Avanti box exhaust now.
Thanks for sharing the jetting! That's pretty close to what I got on a Casa 185 recently (wide neck airbox, BGM filter, Casa S1/S2 Clubman) sans the atomizer which was Q3 and slide which was a 4.5. Can't wait to finally get my GT together.
vegansydney
Postby Storkfoot » Mon Feb 21, 2022 11:30 pm
I have recently swapped inlet manifold from the downdraught 30mm version to the 24/25mm version which is not down draught. I now see your predicament, Vegansydney. Even with an 8mm packer, I have still had to take a dremel out to provide an adequate gap between the carb and engine mount.
Users browsing this forum: Bing [Bot] and 26 guests
