hullygully wrote:also have a check around the outside of the brg as it fits in the casing, you could have a leak there instead of the seal
Fast n Furious wrote:I've got an indian GP on the bench at the moment with a leaking seal around the outer edge. I doubt it's an undersized seal. Most proably an oversized bore, in which case, I hope to get away with wrapping a new seal with a bit of PTFE tape to pack it out.
Leotech wrote:Also check the O ring on the layshaft. 20mm x 2mm Viton ones are available on eBay fairly cheaply
Fast n Furious wrote:Well... the seal was completely goosed and so was the bearing.... and the brake shoes
Users browsing this forum: Google [Bot] and 15 guests
