by gizmo » Wed Jan 26, 2022 10:28 pm
Are the side panel buffers essential. Thinking of removing rear struts as using short runners. Only other use for struts is rear runner boards I presume
gizmo
by hullygully » Thu Jan 27, 2022 10:05 am
probs stops pannels from vibrating also
by Covboy » Thu Jan 27, 2022 11:15 am
without the strut and rubber the side panel can rub on the engine casing kickstart side...
by Covboy » Thu Jan 27, 2022 11:30 am
by citydaz » Thu Jan 27, 2022 9:42 pm
I think the rubbers help to hold the panels in a more secure way, by exerting a slight outward force onto the panel, it gives the clips something to resist against.
Plus creates the correct form of the panel.
citydaz
by missing lynx » Thu Jan 27, 2022 9:53 pm
My only observation is that once you've cut them off if you change your mind you'd have to weld them back on and they're be hidden under the panel anyway. Personally I would just cut the dog leg off the flywheel side because that can just been bolted back on at a later date
by gizmo » Fri Jan 28, 2022 1:28 pm
missing lynx wrote:My only observation is that once you've cut them off if you change your mind you'd have to weld them back on and they're be hidden under the panel anyway. Personally I would just cut the dog leg off the flywheel side because that can just been bolted back on at a later date
Sounds a plan. Way forward Thanks all
gizmo
by Leotech » Sat Jan 29, 2022 11:12 am
Without the rubber buffers the panels vibrate and crack much easier.
Leotech
Users browsing this forum: No registered users and 18 guests
