Lead free solder
Lead free solder
Postby a-teamlambretta » Thu Sep 01, 2022 6:36 pm
What are people using to set their squish ?...just bought some 3.25mm diameter lead free solder and it seems a lot less maluable or harder than the full fat lead ...
Cheers Simon.
a-teamlambretta
Re: Lead free solder
Postby coaster » Thu Sep 01, 2022 9:52 pm
Plasticene works very well 8-)
Postby MickYork » Fri Sep 02, 2022 6:46 am
I've used Blue tack before, but very thin soldering wire (lead free) twisted together seems fine.
Postby hullygully » Fri Sep 02, 2022 9:41 am
3.25mm!!!!!!!!!! how bigs the gap you're checking Si? 2mm should be thick enough :o
Postby a-teamlambretta » Sat Sep 03, 2022 3:33 pm
Well....it was all that I could get at the time... Anyway it eventually hammered it down to 0.95mm..near enough for me lol
a-teamlambretta
Postby hullygully » Thu Sep 08, 2022 7:51 pm
for a 58 stroke bud I'd be looking for 1.1 min
Postby a-teamlambretta » Thu Sep 08, 2022 9:24 pm
60/110...
a-teamlambretta
Postby MickYork » Fri Sep 09, 2022 7:01 am
Just got 1.3mm on my Avanti 225, using twisted solder held in place by Plumbers Mate
Postby hullygully » Fri Sep 09, 2022 11:56 am
Si, you should be looking @ 1.2mm min to 1.6mm max on a 60mm stroke bud :shock:
your piston will tw*t the cyl hd when it heats up & the crank expands :cry:
Postby a-teamlambretta » Fri Sep 09, 2022 12:34 pm
a-teamlambretta
Postby Fast n Furious » Sat Sep 10, 2022 4:05 pm
Squish clearance is more related to the conrod length than the stroke. 1% of conrod length is the usual recomendation, but the engine must have perfectly good bearings.
Postby MickYork » Sat Sep 10, 2022 4:50 pm
Fast n Furious wrote:Squish clearance is more related to the conrod length than the stroke. 1% of conrod length is the usual recomendation, but the engine must have perfectly good bearings.
So you need a good selection of conrod lengths to get your squish right :mrgreen:
Postby Fast n Furious » Sat Sep 10, 2022 6:08 pm
:lol: :lol: :lol:
Postby hullygully » Tue Sep 13, 2022 9:07 am
a-teamlambretta wrote:http://www.dragonfly75.com/moto/SquishVelocity.html
i like to run close ...lol :shock:
easier using DT's info bud :lol:
Users browsing this forum: Nudger and 1 guest
