Untitled by Donnie Canning, on Flickr
Untitled by Donnie Canning, on FlickrAfter some thought about what to do and chatting to Rich Taylor I managed to get a local mate that does great work to sort it, yes, the exhaust ports rewelded and I got a new piston / rings at one oversize (64.5mm) and he rebored it for me too.
I mentioned to him that when Id built it up last year Id ended up using a 2mm head gasket to get a squish of 1.1mm (from memory) which he thought was odd, so on further measuring and looking at everything it turns out that what I thought was a 58 stroke crank is in fact a 60mm! Bonus!
Of course now, I am trying to get it all rebuilt so I can get run in over the summer!
(all measurements are without any sealant or paper gaskets)
So, in that quest (and at his suggestion) I've got a 1mm base packer and a 1mm head gasket as when we looked at it all together this left the exhaust port / transfers at a point where I should get improved performance without it being too peaky and then double check what squish that gives me.
However, I've just built it up and the squish comes out at .73mm which is too small and this is with the 1mm head gasket.
Also I have checked the combustion chamber volume with it built up, TDC and filled to the bottom of the plug hole thread gives me 22.2cc and all that inputted is
Screen Shot 2017-05-13 at 12.38.15 by Donnie Canning, on FlickrThis will be with a 30mm PHBH, MBGM V3 Clubman, static timing at 17 degrees BTDC and mainly for touring use but wanting some good fun speeds too. Im unlikely to go back to an expansion to be honest though if I every do will likely be a franspeed tourer.
Fuel wise I run 3% fully synthetic and standard unleaded.
So, Im thinking that my best option will be to go for a 1.5mm head gasket rather than add .5 to the base? Increasing the head gasket by .5 should give me a squish about 1.2/1.3mm.
Thoughts?
