CasaCooler / SIP Vape
Postby Solid Air » Fri Jun 09, 2023 11:42 am
Anyone using the conbination of CasaCooler and SIP Vape? I'm interested in how close the supplied fan sits to the Casa flywheel cover.
Thanks, Mark
Re: CasaCooler / SIP Vape
Postby bike grim » Mon Jun 12, 2023 10:24 am
Think Rob Gray has done so
Postby dscscotty » Fri Jun 16, 2023 9:13 pm
Hi Mark, I've fitted several, they run close, good for flow, be aware that depending on which cooler it is the fan does at times require the fins machining on an angle to fit correctly
Regards
Scotty DSC
Postby Solid Air » Fri Jun 16, 2023 9:41 pm
Thank you Scotty, that's great info!
Postby Solid Air » Fri Jun 16, 2023 9:51 pm
bike grim wrote:Think Rob Gray has done so
Thanks Gareth
Users browsing this forum: No registered users and 8 guests
