Clutch springs
Clutch springs
Postby stonerosesmod » Sat Nov 29, 2014 2:25 pm
I have standard GP clutch springs with a 4 plate surflex clutch on my mugello 200 and it was suggested on the last dyno it had to use some stronger springs as they seemed on the limit.Not had a problem on the road to be fair,but what springs would you recommend that isnt over expensive and doesnt require popeye to pull the lever in? Ive read about standard Vethpa springs around lammy ones or maybe Taffspeed?
stonerosesmod
Re: Clutch springs
Postby rossclark » Sat Nov 29, 2014 4:30 pm
MB
Lights blue touch paper and stands back...
Re: Clutch springs
Postby stonerosesmod » Sat Nov 29, 2014 5:31 pm
Hey any feedback is welcome ;)
Just been looking around,MBD ones are just over a tenner whereas Taffspeed are half the price.A mate fitted some mallossi springs in his Li and the lever operation is far too heavy for my liking.He doesnt mind, but he is virtually an ape anyway.Anyone tried the Taffspeed ones?
stonerosesmod
Re: Clutch springs
Postby gaz_powell » Sat Nov 29, 2014 6:31 pm
used the mb, taffspeed and SR uprated ones in several TS1 builds - using 4 plate surflex b with no problems
where are taffspeed ones are a fiver ? I`ll have a set for spare !
Re: Clutch springs
Postby stonerosesmod » Sat Nov 29, 2014 6:57 pm
Evilbay :D
stonerosesmod
Re: Clutch springs
Postby rossclark » Sat Nov 29, 2014 7:30 pm
The ones from MB will be MB, the ones from evil bay could be any damn thing...
Re: Clutch springs
Postby Knowledge » Sat Nov 29, 2014 11:03 pm
If you have a heavy clutch, try fitting a nylon lined clutch cable, and consider converting to an RD350 clutch lever (recommended)
Re: Clutch springs
Postby coaster » Sun Nov 30, 2014 9:29 am
rossclark wrote:MB
MB springs get my vote too, I tried Taffspeed ones but found them too heavy. Changed to MB springs and found to do exactly what was claimed. I have them fitted in Reedspeed budget 5 plate clutches in an Avanti 225 and a TS1 225, both have a light clutch action and no slippage 8-)
Re: Clutch springs
Postby stonerosesmod » Sun Nov 30, 2014 12:43 pm
Stroke of luck then! I ordered MB ones yesterday as the ebay ones were open and as rightly said, could be anything.
stonerosesmod
Re: Clutch springs
Postby Captain Pugwash » Sun Nov 30, 2014 4:38 pm
stonerosesmod wrote:Stroke of luck then! I ordered MB ones yesterday as the ebay ones were open and as rightly said, could be anything.
MB does sell some very good quality kit 8-)
Captain Pugwash
Re: Clutch springs
Postby Donnie » Sun Nov 30, 2014 6:14 pm
its a muggy 200.
nylon lined clutch cable and standard springs for a 4 plate clutch, next step is standard vespa over lammy springs. shouldn't need more than that to be honest.
far too many "performance" spring sets that never actually rebound to original length on the market.
im building a gt186 and using standard springs only on my 4 plate clutch
Donnie
Re: Clutch springs
Postby phil23fair » Mon Dec 01, 2014 10:07 am
Knowledge wrote:If you have a heavy clutch, try fitting a nylon lined clutch cable, and consider converting to an RD350 clutch lever (recommended)
Another trick with the nylon lined outer clutch cable is to fit an aircraft grade multistrand inner cable. This really does make a world of difference on a heavy clutch
phil23fair
Re: Clutch springs
Postby stonerosesmod » Mon Dec 01, 2014 8:09 pm
Thanks guys,Ill give the MB springs a go.If they seem too heavy,ill try the other options ;)
stonerosesmod
Re: Clutch springs
Postby burnside » Wed Dec 03, 2014 2:53 pm
I'm using these in my GT200 with standard clutch http://www.granturismo.pwp.blueyonder.co.uk/GT%20Clutch%20spring.htm
burnside
Users browsing this forum: No registered users and 17 guests
