Warkton Tornado No.1 wrote:The 175 S III engine is quite a rarity by comparison with the other capacities, but in my experience very smooth.
I have only ever tuned one & that was already fitted with an Indian alloy finned barrel. I would never do one again unless there was a ton of money upfront to cover the time involved. However, it turned out extremely well.The poor quality, mismatched transfers & chilled - extremely hard - cast iron ports required many hours of work & almost dictated the extent of tune just to get things tidy.
I realise that none of that helps you, but if I can track down my notes of port timings, I will let you know. The tune was not wild but the exhaust was some aftermarket un-named expansion chamber that worked well.
Fast n Furious wrote:Because the Timesert is recessed like you say, then yes, it is likley that a standard length exhaust stud will make contact with the cylinder spiggot, which must be avoided. Shortening the stud is your only practical option.
Good luck finding a threadlocker product. I've never found one that works on exhaust studs. The temperature in this region of the engine is just too high.
Warkton Tornado No.1 wrote:Regarding studs for any position on a Lambretta, I’ve got in the habit of always assessing what will be best within my available stock & fit accordingly. Probably all of them are rolled threads as per OEM.
In general, the exhaust studs I fit will stay in place with Loctite Studlock though I will fit studs that have the best length of plain shank appropriate for the exhaust flange & solid copper gasket. I would never use any other type & if solid copper has not been available - on the odd occasion - bathroom silicon has provided a good seal on it’s own.
The exhaust studs I fit are double nutted to drive in hard to the shank. The nuts are usually M6 10 mm AF Hexagonal long nuts (Toolstation/Screwfix) tapped through to M7 & cross drilled to be lock-wired to each other.
I found my notes for the alloy finned 175 engine that I built seven years ago. The Indian cylinders really are a dog’s dinner & only suitable for people with an awful lot of time to kill. Anyhow, after weeks of work, the result was extremely good for a 175. It was also smooth which was likely due to the 116 mm rod. For the record, I got the bore clearance to 0.003” with the new piston which may have been a Gor(?) with an (eventuallly!) ring gap of 0.015”. Inlet was 151°, Transfers 127° & Exhaust 167°.
Somehow, that machine went far better than it had any right to without drama & I understand would embarrass quite a few ‘tuned’ large block engines. Allegedly
Storkfoot wrote:
Can you anneal the solid copper exhaust gaskets with a blow torch?
Adam_Winstone wrote:^... lol... next Spring.
I'm laughing as I'm in the same scenario re: the 150cc Jap reed converted motor that I put together a couple of months back. I then found that the intended frame needed work, which has very much put this on the back burner.
Funnily enough, it's the first time that I've used a 48 rear sprocket too, which I picked up from a pal.
Cheers for now.
Adam
PS - The reed 150cc is a change for me as I tend to always go bigger but just fancied using up some of my parts that were lying about. Like the V*spa T5, it occurred to me that size doesn't always matter.... does it?
Cheers for now.
Adam
Cheers for now.
Adam
Users browsing this forum: Google [Bot] and 20 guests
