515paul wrote:Hi Mark
The link worked, will order the kit tomorrow.
Cheers mate.
Cheers mate.
vintage65scoot wrote:Hi i remember reading that the last number is the spring strength and the number should be above 6 ie 7 or 8 etc.
I say this as i fitted some from Reedspeed and the drive side one lasted all of 1 week. All had to be pulled apart again very annoying . This is just a cautionary tale not trying to tell you what to do as your rebuilds and engine builds are what people should aspire to cheers
vintage65scoot wrote:Hi Mark ive remembered where i saw this info about seal spring strenght its in the rear of Stickys Manual page 247 it says the forth number can run up to number 10 and seals with the forth number less than 5 should not be used , but he is talking about Rolf seals more confusion !! Not viton but it i cant see what the difference would be as they are going to reach the same temperatures and assume as soft as each other. I didnt bother putting another viton seal back in as i didnt have one at the time as i had a standard Rolf one put that in and has been in for the last year with no problems .
Good luck hope this helps Mark R
soullad wrote:Hi Mark,
When I built up my TS in 2009, I used Viton seals, but as to what type, spring strength etc I cannot recall. That said all I did was fit on the advice of the supplier which at the time was MB. When I replace the bearings / seals I'll post back on this thread with all the info as these have stood the test of time using different fuels / oils all over Europe since then. I have never been fussy regarding what fuel to put in, but always used the best oil I could afford, often Castrol fully synth.
