PHBH30 with Clubman - SIL 200
Postby cobby56 » Sat Feb 21, 2015 4:56 pm
SIL 200 with DellOrto PHBH30 (open) and AF Clubman. Guessing this is a fairly common set up. Could anyone give me carb spec they are running please. Got a couple of motors to do that will be this set up, one for myself and one for a mate, need a starting point. Many thanks. Cobby
cobby56
Re: PHBH30 with Clubman - SIL 200
Postby St George » Sat Feb 21, 2015 5:22 pm
Hi Cobby, if you log in to Bristol Lamb' Club site. on the left of the page in green writing are all the settings for your carb and many others. Hope this helps, Colin.
St George
Postby cobby56 » Sat Feb 21, 2015 8:27 pm
St George wrote:Hi Cobby, if you log in to Bristol Lamb' Club site. on the left of the page in green writing are all the settings for your carb and many others. Hope this helps, Colin.
I'd looked on there and couldn't find anything specific to a clubman type exhaust set up, plenty of info on PHBH coupled with an expansion (JL etc), got plenty of experience of jetting motors with pipes but not sure of starting point with box exhausts. Maybe I was looking in wrong place ?
Anyone actually running SIL200 with PHBH and clubman, thanks
cobby56
Postby SimonC » Sun Feb 22, 2015 6:43 am
Cobby,
Not exactly the same but should be close.
Ron Moss stage 4 cast 225
Avanti Clubman
PHBH 30 open
40 slide
AV 226
Idle 50
X13 second clip
350 needle/float valve
Main 125
Hope that helps
Simon
SimonC
Postby cobby56 » Tue Feb 24, 2015 10:05 pm
SimonC wrote:Cobby,
Avanti Clubman
PHBH 30 open
40 slide
AV 226
Idle 50
X13 second clip
Main 125
Hope that helps
Simon
Thanks Simon, just querying Atomiser ?
Any other offers gratefully received
cobby56
Postby Adam_Winstone » Tue Feb 24, 2015 10:58 pm
That would have been an easy typo and meant to be AV266. You might find that an X7 on T2 runs well too.
Postby SimonC » Wed Feb 25, 2015 7:00 am
Well spotted Adam,
AV266
Have used both X13 and X7. Both work, the X13 seems cleaner on my set up!
Simon
SimonC
Postby MickYork » Wed Feb 25, 2015 8:19 am
If you go on the Scooterotica forum they have a carb' section which has a variety of set-ups.......worth a look.
Postby DaveTomo » Wed Feb 25, 2015 2:49 pm
viewtopic.php?f=6&t=182 AF jetting guide second one down 200 with delly 30 & clubman,
DaveTomo
Return to Carburettors
