GT Kit Carb Rubber Options
Postby Angry Bloke » Sun Mar 15, 2015 2:38 pm
Having a bit of a " laugh" trying to fit a 30 PHBH to a GT kit ( standard side ) with a 13ltr tank with cut out :?
It used to fit ok with an RT kit but the reed valve manifold appears to be shorter than the CDC type so the carb top hits the edge of the tank
Also the rubber is slightly nipped against frame tube
I have fitted a shorter 300mm shock which has dropped the barrel thus reducing the nip but I was wondering if there are any longer rubbers available
I've tried an MB rubber and a Mallossi rubber - the Mallossi is about 5mm longer and the diameter is slightly smaller which helps with both issues but is anyone aware of longer rubbers :?:
Angry Bloke
Re: GT Kit Carb Rubber Options
Postby dickie » Sun Mar 15, 2015 3:13 pm
I thought the 30mm manifolds were suitable for both sides now.
Have you got an old manifold? Or maybe it has to be used with a rubber from gran turismo?
Postby Angry Bloke » Sun Mar 15, 2015 3:23 pm
dickie wrote:I thought the 30mm manifolds were suitable for both sides now.
It's a new kit so presume it's the dual direction version.
I didn't realise Richard sold rubbers but I just found it as part of his carb kits - I will contact him later to see if they are any different from the norm
Cheers :D
Angry Bloke
Postby Angry Bloke » Mon Mar 16, 2015 11:49 am
I could always try the offset cone option I suppose :idea:
Angry Bloke
Postby Fat Trucker » Mon Mar 16, 2015 2:56 pm
Or buy some car radiator hose and cut to whatever length you require and you`ll have some left over for future projects.
ove
Fat Trucker
Postby Angry Bloke » Mon Mar 16, 2015 8:23 pm
Fat Trucker wrote:Or buy some car radiator hose and cut to whatever length you require and you`ll have some left over for future projects.
ove
:idea: thanks Ove - the Camlam rubbers are just lengths of hose I think
Angry Bloke
Postby coaster » Mon Mar 16, 2015 8:41 pm
What's the clearance like with you sat on it Peach?
Postby rexton270s » Mon Mar 16, 2015 8:57 pm
rad hose tis gud! had a imola and couldnt keep the phbh on......ford transit water hose did it!
rexton270s
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
