by landybretta » Mon Mar 16, 2015 9:33 pm
I have read the comments on the Jockeys Boxenstop Headlight thread but is there anyone out there who can answer the following.
Which would be the best option for my LI Special
My current H4 conversion with an Osram Nighrbreaker 55/60w fitted with the original type reflector and glass.
OR
Jockeys Boxenstop Headlight with the 35/35w bulb with its modern reflector and glass (plastic)
Running on 12v with rear led & led speedo bulb.
landybretta
by coaster » Mon Mar 16, 2015 9:53 pm
I'm the same as you, I have been running home made H4 conversions for a few years now also with the Osram 55/60. Good light but I found that there wasn't enough output from my stator to keep the battery fully charged (wassel DC). I bought the Boxey lamp with the hope of achieving the same light output but with lower power consumption but never did try it with the supplied H4. I wish I had now but instead went straight to an H4 HID conversion which as mentioned on the other thread, is amazing.....if I don't get electrocuted from the extended wires
Users browsing this forum: No registered users and 17 guests
