rev limiter?
rev limiter?
Postby stonerosesmod » Thu Apr 09, 2015 8:30 pm
Hi all,
Recently fitted a mugello 198 and a new GP crank with lightened flywheels to my mates Li125.
It all went together well and I made sure the piston was the correct way, ring gaps and squish were spot on etc.
Carb is a nearly new 26phbh with small type ram air,
53 pilot
AV266
X2 needle
Started off with a 115 main and she fired well after a few kicks, strobed timing to 18 degrees.
She revved nice and clean but bogged down at high revs like a blocked main jet.
As hes running in hes gone steady for 30 miles so far so tonight I dropped main to a 110, but still bogged down at high revs.
Changed carb and cleaned jets to my good spare 26phbh, still same!
Took filter off...same.
Checked fuel flow which is fine.
Changed plug, same.
Changed cap & lead..same
Changed cdi...same....pulled cut off wire out..same.
I tried it up the road and it goes like a stabbed rat with throttle opened up until revs get high then its like its hit a rev limiter.Im thinking pick up on stator now? Its surely all thats left?
stonerosesmod
Re: rev limiter?
Postby Rich Oswald » Thu Apr 09, 2015 8:41 pm
You seem to be contradicting yourself here as bogging down, imo, indicates too much fuel whereas a blocked main jet indicates fuel starvation. Both may give similar symptoms though. Have you tried dropping the needle by one notch? I know this only really affects the mid-range but I found that it does have some effect on the main jet too.
Re: rev limiter?
Postby stonerosesmod » Thu Apr 09, 2015 9:10 pm
Not bogging down as such but wont rev out like it should.On the road with throttle cracked open it accelerates clean until the revs get high then seems to missfire.Needles in the 2nd down slot and carbs set up the same as my mugello 198 was which ran perfect.Even open mouthed its the same which makes me think its electrical
stonerosesmod
Re: rev limiter?
Postby stonerosesmod » Thu Apr 09, 2015 9:52 pm
Doing that tomorrow Eden, he bought the stator last year but think its a cheapo one.Hopefully it will cure it.Dont you just hate it when you spend ages building someones engine to the best of your abilities yet the gremlins still keep rearing their ugly heads!
Loving your vids btw, I hope the GT kits running well!
stonerosesmod
Re: rev limiter?
Postby dscscotty » Thu Apr 09, 2015 10:31 pm
not disputing the possibility of stator/pick up problem but change the x2 needle to a x7?
Re: rev limiter?
Postby Donnie » Fri Apr 10, 2015 12:03 am
Umm what exhaust and what gearing please??
Donnie
Re: rev limiter?
Postby stonerosesmod » Fri Apr 10, 2015 6:13 am
Doh! must have had a blonde moment last night! sorry,the needle is an X7
Running an Li125 box with 17x46 and an Ancillotti
stonerosesmod
Re: rev limiter?
Postby terryj » Fri Apr 10, 2015 7:42 am
i had problems coming home from isle white 1 year had to toddle along at low revs my problem was down to the indian cdi on way out changed cdi and it ran fine again
terryj
Re: rev limiter?
Postby MickYork » Fri Apr 10, 2015 7:47 am
It does sound electrical. I had a similar problem which turned out to be the plug. Wouldn't rev out in 4th and juddered a bit as though fuel but after stripping and changing the carb' I eventually changed the plug and worked fine.
Re: rev limiter?
Postby Donnie » Fri Apr 10, 2015 2:47 pm
hmmmmmm certainly starting to sound electrical I have to admit. Id think swapping out the plug / cdi and then possibly the stator for known good ones are gonna be the way forward. Check the rivets on the stator too.
Donnie
Re: rev limiter?
Postby missing lynx » Fri Apr 10, 2015 3:56 pm
did you open up the transfers in the casing?
Re: rev limiter?
Postby Wack » Sat Apr 11, 2015 9:27 am
Miss match between pick up and flywheel triggers. MB sell a kytronic thing that is supposed to eliminate the problem.
Re: rev limiter?
Postby Paulnobodyimportant » Sat Apr 11, 2015 9:55 am
This has happened to me and it was a faulty CD unit.
Paulnobodyimportant
Re: rev limiter?
Postby stonerosesmod » Sat Apr 11, 2015 12:47 pm
Changed the plug,cap,lead and Cdi for good spares and still no joy.Hes coming round soon and im gonna try changing the pick up for a new one as i dont have a spare stator.
stonerosesmod
Re: rev limiter?
Postby Storkfoot » Sat Apr 11, 2015 12:57 pm
What type of flywheel is it?
Re: rev limiter?
Postby Adam_Winstone » Sat Apr 11, 2015 5:55 pm
^... what type of stator was it and what type of pickup did you use to cure it?
Re: rev limiter?
Postby Adam_Winstone » Sat Apr 11, 2015 7:51 pm
Ta
Re: rev limiter?
Postby Captain Pugwash » Sat Apr 11, 2015 8:41 pm
Diode test the pickup, look for the same readings in both direction (test leads reversed) Indian usually 0.059. Italian usually 0.071.
Multimeter with a diode test function required.
Mark
Captain Pugwash
Re: rev limiter?
Postby stonerosesmod » Mon Apr 13, 2015 5:59 am
Indian lightened flywheel.Changed the pick up to a new one and that cured it :)
stonerosesmod
Users browsing this forum: Google [Bot] and 14 guests
