Hi, wasn't sure whether to post this in the carb section or here, so if it's in the wrong place let me know and I'll move it.
Went out on a long-ish run on my standard Li 150 Series 2 today to the Abingdon Oddballs rally, the scooter was running lovely for about the first 10 miles but then power loss and back fire at closed throttle.
Spark seemed fine and scooter would start up again when cool, but the whole day was a stop..start affair and had to nurse it home!
I think the electrics are fine and my guess is that the slow running circuit in the carb isn't letting enough fuel through when the engine is warm - almost like it's evaporating before it gets into the cylinder.
I'm currently running a SPACO MA19 copy which I'm guessing is the root of the problem, at the rally I picked up a SH1/18 carb for Li150 S3, if I change the manifold to an 18mm type is the carb a straight swap and a worthwhile upgrade? I've heard the MA19 type are often troublesome!
The other option I have is upgrading the original Italian BS5 carb (leaks like a sieve) to BS7 spec with the conversion kit, but that's £45 + extras.
Anyone have any other advice? Or already running a S3 carb on a S2?
Thanks,
Rog
