13ltr tank
13ltr tank
Postby panda » Sat May 02, 2015 9:41 pm
I have just fitted a 13ltr tank to a gp 200 with 28 mm carb and was wondering is it best to leave the tool box out cause there's not much room for any cables etc
panda
Re: 13ltr tank
Postby MickYork » Sat May 02, 2015 9:58 pm
toolbox can stay. I agree there's not much room but it's adequate for routing the cables. sometimes a 90 degree elbow out of the carb' can help.
Re: 13ltr tank
Postby panda » Sun May 03, 2015 8:37 am
When you say 90 degrees is that the manifold your talking about
panda
Re: 13ltr tank
Postby MickYork » Sun May 03, 2015 10:21 am
No, not the manifold the outer throttle and choke cable. A 90 degree elbow helps send them in the correct direction as opposed to straight up.
Re: 13ltr tank
Postby A64yorkie » Sun May 03, 2015 8:00 pm
here you can see its a tight fit but no problem . to get an air filter in we had to cut 70mm square out of toolbox corner and mod panel alls good now even has LTH reedvalve its just got a longish throttle cable and fits between A64yorkie :D
A64yorkie
Re: 13ltr tank
Postby Rich Oswald » Sun May 03, 2015 8:07 pm
Why not just have the filter horizontal pointing toward the rear of the scooter?
Re: 13ltr tank
Postby A64yorkie » Sun May 10, 2015 7:00 pm
because of all crap and dust at lower level . also may interfere with air cooling :)
A64yorkie
Re: 13ltr tank
Postby dave411 » Sun May 10, 2015 7:15 pm
I would take it out and fit a legshield box.Just as I am doing ;)
dave411
Users browsing this forum: Google [Bot], W3C [Validator] and 16 guests
