Picking up from standing
Postby lammydave » Wed May 13, 2015 7:04 pm
If my scooter needs lots of revs and a bit of clutch slipping to pull away smoothly, what carb settings should I be looking at changing?
It's an RT195 with a 30mm PHBH
lammydave
Re: Picking up from standing
Postby MickYork » Wed May 13, 2015 7:27 pm
What's exhaust and gearing ? What's your timing set at ?
Postby lammydave » Thu May 14, 2015 6:11 pm
pacemaker box
JL3
19 degrees
lammydave
Postby missing lynx » Thu May 14, 2015 7:04 pm
what front and back sprockets have you got
Postby CHRIS in MARGATE » Thu May 14, 2015 10:58 pm
Possibly too rich mixture at the pilot circuit. Smaller pilot jet might make a difference.
Postby Raveydavey » Fri May 15, 2015 5:17 am
How about in other gears when you're off and running? If it is carb and not gearings, which it could be, I'm guessing you're giving it a load of throttle to slip the clutch in which case it could be slide, needle main jet or all three. I had a similar issue, which changing clip position cured to some extent, but permanent fix came from a leaner slide.
Raveydavey
Postby lammydave » Fri May 15, 2015 6:05 am
off and running, it's fine... if I'm sitting on the front of the seat, the acceleration pushes me to the back..... 8-)
so i'll kick off with the pilot and see what happens...
spending all day tomorrow on a service as I'm taking it to France in 6 weeks.... :)
and thanks, guys!
lammydave
Postby MickYork » Fri May 15, 2015 7:17 am
what is your carb' jetting ? be sure to check the plug if you drop the pilot jet (could run too lean).
Postby lammydave » Sat May 16, 2015 5:06 pm
MickYork wrote:what is your carb' jetting ? be sure to check the plug if you drop the pilot jet (could run too lean).
thanks, mick.. It's a 55... got a 52 and a 50 coming, so will try the 52 and do some plug chops..
lammydave
Users browsing this forum: No registered users and 9 guests
