stator plate
stator plate
Postby bricky36 » Mon Jun 08, 2015 4:05 pm
Going to fit gp crank in my li125 engine, I know I need gp flywheel, but can I fit a gp stator plate?
or does it have to be a Li stator plate, is there a difference?
bricky36
Re: stator plate
Postby Captain Pugwash » Mon Jun 08, 2015 4:14 pm
GP stator should be fine on the li flywheel and crank just check the centre hole is wide enough for the LI boss to fit inside.
GP stators have a bigger centre hole in the middle than early LI ones but sometimes they are a tight fit because it might not be the later type GP stator that you think you have.
But if your running an early Brass type flywheel it will be fine whichever 6 pole Ducati stator you fit.
Captain Pugwash
Re: stator plate
Postby bricky36 » Mon Jun 08, 2015 4:22 pm
So if was going to fit a gp electronic flywheel kit, it would fit ok on li engine with gp crank?
bricky36
Re: stator plate
Postby Captain Pugwash » Mon Jun 08, 2015 4:27 pm
Yes if you are changing the crank and flywheel and fitting the GP electronic kit that's the best way to do it IMO.
Captain Pugwash
Re: stator plate
Postby bricky36 » Mon Jun 08, 2015 4:30 pm
Excellent, thank you.
bricky36
